Support secure provisioning files for Yealink phones
Discussion in 'Ideas' started by accent5, Jun 7, 2016.
  1. accent5
    Feb 11, 2015
    Yealink offer the ability to encrypt the configuration files on the provisioning server.
    This allows us to encrypt on the server and decrypt with the phones own unique AES key.
    Man-in-the-middle and brute forcing the provision server would then be rendered useless.
