Support Shared Parking with BLF In IOS/Android App
Discussion in 'Ideas' started by JStellato, Jun 16, 2017.
Support Shared Parking with BLF In IOS/Android App 5 5 2votes
5/5, 2 votes
  1. JStellato
    Dec 17, 2015
    33
    6
    Having users bring up the keyboard and type in SP1 is a workaround, it would be nice to have proper BLF support in App for this.
  2. kenttec
    Jul 29, 2016
    62
    18
    Hi there, I know this is an old post but here goes, there is a work around for this as we have found.
    Firstly create an extension and name it SP1
    Within the forwarding rule (Avaialable) of this extension set it to forward to a number and make that number SP1
    See my attached image
  3. WolfgangOne
    Nov 17, 2016
    25
    9
    Note that with this method, it doesn't give BLF/Presence for that extension - that is, you cannot tell if something is already parked there.
    I'd also like some actual mechanism for dealing with this. Since the mobile client can see presence of your other extensions, it seems like it should be easy enough to macgyver it together.
