Support TCP signaling
Discussion in 'Ideas' started by dig1234, Aug 5, 2016.
  1. dig1234
    Jun 1, 2015
    75
    With UDP, SIP messages which exceed MTU size need to be fragmented by IP layer which can cause hard to diagnose issues with lost packets. All routers in between need to allow for fragmented packets which is not always the case. Especially in VPN environments. 3CX should support TCP signaling to the phones for this reason.
