Supported gateways in new V8 less?
Discussion in '3CX Phone System - General' started by kanshare, Apr 1, 2010.
  1. kanshare
    Apr 3, 2009
    26
    Has anyone noticed that the number of supported gateways appears to be less. Such as Audio codes. I finally managed to get my hands on what i thought was a supported gateway and wanted to try out the templates but it was not there anymore.
    But i do see some instructions how to generate the file to upload into the gateways. The particular one i am looking at is the Audiocodes MP-114?
    Sorry i didn't notice any thing that said there were less gateways just items on support and tested not supported gateways.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. kanshare
    Apr 3, 2009
    26
    Ah Thanks.
    Yes i found the wiki got a bit concerned that i was losing my mind as i remembered seeing it in the gateway list before.
    Anyway manage to get it to work using the normal configuration method.
