Supported Hardware
Discussion in '3CX Phone System - General' started by jcarlos, Dec 6, 2007.
  1. jcarlos
    Dec 6, 2007
    6
    Is there any list of the supported hardware for 3cx free edition?
    I heard about some modems can be used on some other PBX software, so I want to know if it is possible with 3cx, thanks.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
  3. jcarlos
    Dec 6, 2007
    6
    Well I saw that some normal win modems can be used as X100p clones, and use that on asterisk, so what I want to do is use one of those with 3cx...
  4. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    3CX does not support any hardware inside the box. All communications is done with SIP devices. There are tons of SIP devices to handle single phone lines to those that can handle T-1's.
    PBX's like Asterisk do what your talking about, but 3CX decided to take a different approach and not worry about having to support a ton of different cards which is pretty smart as they can concentrate on the PBX software itself and not on drivers.
