supported PSTN gateway with 24 ports
Discussion in '3CX Phone System - General' started by jimmy2710, Mar 17, 2009.
  1. jimmy2710
    Mar 17, 2009
    hello all..
    im new in this forum, and interested to buy 3cx phone system. i want to know what gateway to use that has 24 ports to connect the system with PSTN lines.. we are looking for having maximum of 24 external PSTN lines and over 200 extention internaly. i know that 3cx phone system can support unlimted number of extentions but i dnt know what PSTN gateway to use to satisfy the need of the company
    thank you
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Patton IP Channelbank will do the job
    http://www.patton.com/products/pe_products.asp?category=364
    * 12, 16, 24 or 32 FXS or FXO ports - Simultaneous voice or fax calls on all ports. Advanced local call switching.
    * Full SIP and T.38 support - Supports the complete range of industry standard VoIP: SIP, H.323, T.38 fax, fax and modem bypass, DTMF relay. Codecs G.729, G.723 etc.
    * Secure Toll-Quality VoIP - DownStreamQoS and Voice-over-VPN with adaptive traffic management and shaping for maximum voice quality and secure voice communication.
    * Complete Access Routing - Two 10/100 Ethernet ports with auto MDI-X. Access router with NAT, Firewall, PPPoE, DHCP, DynDNS, multiple VLANs & VPN with IPSec*
    * Optional Integrated WAN uplink - Choose from V.35, X.21, T1/E1, ADSL or G.SHDSL data interfaces in addition to the two Ethernet ports.
    * Outstanding Interoperability - Interoperable for voice and T.38 fax with leading SIP service providers, soft-switch vendors and Asterisk™ IP-PBX
  3. jimmy2710
    Mar 17, 2009
    hello..
    is this model supported and tested with 3cx system?
    thank u
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    306
    It will work fine with 3CX - but you must undertake the configuration yourself, there is no template for it in the configuration.
