Supported/Recommended DECT handsets
Discussion in '3CX Phone System - General' started by pjr, Mar 21, 2012.
  1. pjr
    pjr New Member
    Oct 5, 2009
    154
    Since SNOM are no longer officially supported, can anyone advise as to if there is a supported by 3CX DECT option?
    Also if anyone has any experience with using DECT SIP phones sucessfully with V10 I would be interested in hearing what you are using?
    Paul
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Hi Paul,
    I have used both Snom M9 and Gigaset DECT phones. Shortly I am going to use a KXT Dect phone that should allow roaming between base stations. Both work fine with version 10, although not supported.
    Richard
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Richard... Which Pany model will you be using? Am curious as I use them, but while rumored to be coming, I have not seen the one that allows roaming between base stations.
    I have been using the kX-tgp500 and 550 quite frequently and really like them save 2 issues:
    1. The web interface must be turned on manually and then has a timeout after which it must be turned on again
    2. The phone book is a download that also must be done manually. I use the Aastra phone book and then save in a unicode format.
  4. RichardCrabb1
    Mar 7, 2009
    196
    The DECT phones that I will be testing is the RTX8660 - not the Panasonic KXT. These are meant to allow roaming between base stations and are a very reasonable price. I'll let you know how it goes. The web interface looks good. Preliminary testing shows that they are easy to set up, but at the moment the two base stations are at very different levels of firmware - so it is no use testing for roaming until I get them the to the same level. This is potentially for a school, as they have a number of staff that roam around a large site.
    Richard
  5. Jaco Kriel
    Feb 17, 2017
    Hi there
    Any luck with these devices?
  6. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    Sorry, didn't check date on this thread - super old.
  7. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Check latest news on this. We have new DECT / ATA provisioning in V15 Sp4.
