Supported wireless handsets
Discussion in 'Windows' started by StewartGilray, Jun 6, 2011.
  1. StewartGilray
    Jun 6, 2011
    11
    There is likely a list for this already, but I cannot find it anywhere...
    I just bought a damned Cisco 7920 to find out it's not supported.
    Thanks in advance.
    Stewart
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, just because its not supported by 3CX does not necessary mean it wont work with 3CX, just that it may not have been tested.
  3. StewartGilray
    Jun 6, 2011
    11
    It's not SIP compatible, and there is no SIP firmware for it, it is SCCP only. Any suggestions?
  4. davidbenwell
    Apr 27, 2010
    704
    in that case, it will NOT work with 3CX, you need to purchase a SIP based phone.
  5. StewartGilray
    Jun 6, 2011
    11
    Hence the post, asking for which handsets ARE compatible.
  6. davidbenwell
    Apr 27, 2010
    704
    Cisco WIP310 Wireless-G IP Phone
    SNOM M3 DECT IP Phone
    Siemens A580IP Dect SIP Phone
    the above are a few that work
