survey
Discussion in '3CX Phone System - General' started by jits04, May 8, 2007.
  1. jits04
    May 2, 2007
    76
    Who has completely changed traditional PBX?
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    we try do change completly but to get the same comfort we decidet to do this only if we have 2 different internetgateways (different line and provider ) and redundant hardware for failover and different vip providergateways. as long as we have not this all we use traditional and vioip pbx.
  3. no1daag
    Feb 8, 2007
    29
    We are about to change but proberly we need to use both a while because we need to use our CRM system for sale and support department.
    We are two company how will become one. Our sale/support are using a Samsung DCS VIp PBX with the feature that with incoming calls our CRM system popup with info about the customer and we can get working directly. We try to implement this to 3cx pbx but it takes time.
    Right now we are at two addresses but we thinking too move together at an new address and hopeful with a 3cx pbx.
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    how do you do this ? we think about try something close to this.
    get the info from the logfiles or posible from db ?
