Swedish translation
Discussion in 'Windows' started by lillenicke, Oct 11, 2010.
  1. lillenicke
    Oct 11, 2010
    Is there any interest in an Swedish translation? And if there is what do i have to do to get started helping you?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,422
    61
    Thanks for your help - I will send your proposal to our tech support in charge with this and they will contact you.
    However, if you want, I can attach here tomorrow the "master" translation file (english). All you have to do is to replace/translate english text strings with swedish ones and to save the file with a filename as strings_....ini, such as strings_se.ini, then copy it into 3CXPhone's language folder (acessible from main menu / Debug / File /Configuration folder) and then, from Preferences dialog, expand the Language combo and select it to use.
    Regards
    vali
  3. lillenicke
    Oct 11, 2010
    Sure, if you Will post a master, i Will give it a try. And if you want to i Will share it.
  4. lillenicke
    Oct 11, 2010
    I forgot, right now i am using the beta version. so hopefully the master will be for that version
  5. lillenicke
    Oct 11, 2010
    Can you please post the masterfile so that i can start my work.
    I have done some testing on the German language file, but my German isn´t that good so an English Master would be great.
    //Niklas
