Switch from Internal IP to Internal FQDN
Discussion in '3CX Phone System - General' started by Frank86, Mar 11, 2018.
  1. Frank86
    Jan 18, 2018
    79
    Is it possible to switch from internal IP to internal FQDN without reinstalling 3CX?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,217
    173
    Hi Frank86,
    You can now change private IP's without having to re-install, but I have seen nothing to support that you can change from private IP to FQDN without a re-install, so I think you still need to do this.
    Also you must ensure that you have a manageable DNS server on your local LAN subnet to support the domain name to private IP either Windows DNS or Firewall/Router.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,108
    166
    Yes, you can if you installed the software using an internal DNS
    Make sure your internal fqdn resolves to your 3cx server
    Edit each phone, under 'Phone provisioning' change 'Select interface' to your fqdn
    If you selected internal IP address, when installing then it will require a reinstall
    #3 Saqqara, Mar 11, 2018
  4. Frank86
    Jan 18, 2018
    79
    Thank you. I'll reinstall it.
