Switch to BT line from voip
Discussion in '3CX Phone System - General' started by stuarty007, Nov 1, 2010.
  1. stuarty007
    Nov 1, 2010
    Hi there I have a client that has a 3cx phone system in their office going through voip and they have recently taken the internet out of their office and was wondering how I go about changing the system so that it goes through the BT line so that they can still make calls until they get a new internet provider?
    Thanks in advance
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    You'll need a gateway to achive this, the website below lists those supported by 3CX under the topic 'VoIP Gateways'...
    http://www.3cx.com/blog/support/
    ... and as you're in the UK these guys can easily supply what you need...
    http://www.voipon.co.uk/voip-gateways-c-3.html
