Switchboard layout
Discussion in '3CX Phone System - General' started by gustavskii, Jan 24, 2017.
  1. gustavskii
    Jan 26, 2016
    61
    Hello
    We recently switched to v15 from v12.5 and the new switchboard doesn`t give us a lot of customization options.
    The biggest issue for us right now is to see calls for individual queues. There is no option to sort them or separate calls from each other.
    Is there a way to make switchboard the way it was before?
    MatthewS likes this.
  2. MatthewS
    Jan 27, 2017
    Bump...
    Anyway to get switchboard to have similar layout/information as default presence screen in 12.5?
  3. MatthewS
    Jan 27, 2017
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
