Switchboard on 3CX phone
Discussion in 'Ideas' started by segurtec, Dec 10, 2015.
  1. segurtec
    Jul 10, 2014
    Select the Switchboard right access to the extension. At the moment any extension cal select any of this View on the Switchboard:
    User; Receptionist; Manager; Q-Manager; Wallbord.
    The idea is to limit some users (extension) to access some of the Views.
    Best regards
