Switchboard shows stuck calls / doesn't update
Discussion in '3CX Phone System - General' started by GabrielVE, May 3, 2017.
  1. GabrielVE
    Oct 25, 2016
    31
    Hi All,
    Has anyone experienced an issue with the Switchboard Not Updating or Showing calls that were like finished for hours ago? and only way to correct is to re-launch the 3CX windows app?
    Do you have any alternative/permanent fix?
    Thanks,
  2. daktur
    daktur New Member
    Oct 15, 2015
    227
    8
    When i faced this issue, I use to force end the call, by right clicking it, and it was back to normal.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,380
    454
    Do you have a stuck call in the system or is the presence information not updated in the switchboard?
  4. NTB Inc
    May 2, 2017
    21
    10
    Yes, since upgrading to v15 from v14 we have seen this issue, we are running latest build of the clients and sometimes 1-2x per day will need to close/start 3cx client to get it to update. In v14 we rarely if ever had to restart. We have not opened case with support as we are eagerly awaiting v15.5 to become GA so we can just use web wallboard and be done with GUI Client.
    To add more detail....if we login to the current active calls in admin gui that is displaying correct current calls, its just the client side wallboard that is not refreshing the data. A simple close/open and the data immediately refreshes to current.
  5. YiannisH_3CX
    May 10, 2016
    6,380
    454
    @NTB Inc
    This might indicate that you have a network issue as the client will stop updating the presence information only if network connectivity is lost and regained. At that point you will require a restart of the client to regain presence information (we are aware of this issue). Can you tell me the version of the client and the PBX you are running?
  6. NTB Inc
    May 2, 2017
    21
    10
    One scenario we have reviewed is if the TCP/UDP timeouts across our VPN are contributing but we have these set to high values and also wasn't a problem in v14.
    We are running PBX version 15.0.62928.5 and 3cx client 15.0.60903.0
  7. YiannisH_3CX
    May 10, 2016
    6,380
    454
    Thank you for the update,
    Please note that the issue will be resolved, most probably when 15.5 arrives.
  8. NTB Inc
    May 2, 2017
    21
    10
    Ok great, we have a scheduled task to stop/start it so hasn't been a huge deal. Are there any timeframes of when 15.5 will be a GA release and available to update via Update option in GUI?
  9. YiannisH_3CX
    May 10, 2016
    6,380
    454
    I do not have an ETA for the release as this is still being tested and worked on, i guess it will depend on how well the testing of the Alpha goes.
  10. GabrielVE
    Oct 25, 2016
    31
    Thanks for the update YiannisH, hopefully it gets resolved by the next update
  11. GabrielVE
    Oct 25, 2016
    31
    Hi YiannisH, 15.5 was already released and in Beta state, don't want to apply it in our environment yet and waiting for the stable build but just wanted to check if you can confirm that the fix for this issue has been applied?
    Thanks,
  12. StefanW
    Jun 2, 2009
    1,217
    89
    the final is there! since 2 days. It contains an fix for staled connection and the brand new web client!
  13. GabrielVE
    Oct 25, 2016
    31
    Thanks Stefan! didn't notice that final release was already deployed :)
    We've updated and will monitor the issue
    Thanks,
    Gabe
