SWitchvox setup
Discussion in '3CX Phone System - General' started by morganc14, Mar 14, 2012.
  1. morganc14
    Mar 14, 2012
    Hey guys-
    We are struggling with getting the 3cx set up with our Switchvox 5.0 system. Can someone help with any special settings, etc that we may be missing? thanks.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Switchvox is a competitive product, not sure why you would want to setup 3CX with it.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I'm a bit curious as to why you are trying to setup switchvox with 3cx, are these two systems at different loctaions?
  4. morganc14
    Mar 14, 2012
    Well, to answer both of you, we are not using 3cx in a PBX fashion. We need to have remote users dial into and from our PBX remotely. So, we are using the 3CX softphone 6 for this purpose. However, we are struggling with the set up as itis not registering fully.
