Sync Adressbook via ODBC
Discussion in '3CX Phone System - General' started by wtrbhe, Nov 19, 2015.
  1. wtrbhe
    Oct 9, 2015
    22
    Hi Everyone,
    i've used sync via ODBC in V12.5 and it worked like it should. Since the update to V14 SP1 the incoming numbers will not be resolved anymore. Using the test tool everything works.
    Is there a way to see, what the odbc-search is doing?
    EDIT: Can someone tell me please, where the log for company phonebook is gone in V14? The known file "3CXCompanyDirectory.trace" from V12.5 does not exist anymore.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please open a ticket on our support portal for further troubleshooting on this matter.
