syncing private phonebook with snom
Discussion in '3CX Phone System - General' started by Biber, Nov 21, 2017.
  1. Biber
    Jul 28, 2015
    23
    I want to sync my contacts (which are in my private phonebook in the 3cx webclient) automatically with my snom 760. Is it possible?
    The snom phone has already all extension numbers of the Phone System, so it must be possible to sync the provate phonebook, also.
    But I can't find how I have to configure it.
  2. StefanW
    Jun 2, 2009
    1,199
    79
    no, only the company Tbook is available on IP Phones. For your private contacts use the 3CX WebClient, anyway much more convenient to use and search then on the device it self.
  3. Biber
    Jul 28, 2015
    23
    ok, and can avoid that the provisioning overwrites the internal snom phonebook?
  4. StefanW
    Jun 2, 2009
    1,199
    79
    yes this you can, but here the disclaimer on this function.
    If once the phonebook gets messed up and cant remove add or shows wrong numbers you only can reset the phone.
    If agreed go to Settings - Parameter - Search for SNOM_TBOOK. The parameter - set it to false. Reprovision devices
  5. Biber
    Jul 28, 2015
    23
    can I do this only for a few users/extensions?
  6. StefanW
    Jun 2, 2009
    1,199
    79
    nope
