Syncronizing "User Status" with DND
Discussion in 'Ideas' started by 3cxMan, Oct 19, 2015.
  1. 3cxMan
    Sep 30, 2014
    When a User has set the Status to "do not disturb" the state from DND is not syncronized. This means: The DND is OFF.
    Can you change, that in this case, the DND will be also set to ON?
    For me is this a very inportant point, because the the ringgroup work perferfect, because it will not ringing, when the User Status is set to "do not disturb"
