Syspine 310
Discussion in '3CX Phone System - General' started by rodspode, Sep 21, 2009.
  1. rodspode
    Sep 21, 2009
    Is is possible to configure the Syspine 310 IP phones to use 3CX?
    We won't use the RP box, just a regular Windows Server 2008.
    I have used Response Point for the past two years, but as Microsoft would not be developing it further, I would like to move to 3CX.
    We have 6 lines and 18 phones.
    Thank you.
    Rod
    10,757
    286
    From what I've found... http://www.syspine.cn/Syspine-IP-Phone-310-Specifications.html they are SIP 2.0 compliant, which means they should work.
    As long as you can get into the settings and change them (i.e.,they aren't locked) then, with some trial and error you should be able to get them working. Some of the key specific features may have a bit of a problem but you might as well give it a go if it means NOT having to buy all new sets. Try modifying one set, that of the least liked person in the office (sorry, we're just taking your phone for a week or so...) and do some (extensive) testing before moving on to the rest.
