system access
Discussion in '3CX Phone System - General' started by jofer, Jan 23, 2013.
  1. jofer
    Dec 5, 2012
    66
    Hi There
    Is there a way to have different levels of access to the system?
    Like administarator will have full access, and another level where the user will not be able to see important info like "passwords"
    Regards
    Johan
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Some functions (3CX MyPhone, Call reporting) can be accessed by extension number and voice-mail pin code.
