System crash and HDD overflow with endless 3cxSystemService..log files within 9 hours?!
Discussion in '3CX Phone System - General' started by Fritz Reinhardt, Mar 16, 2018.
  1. Fritz Reinhardt
    Jan 30, 2018
    12
    Hi everyone!
    Have you ever had a problem like this??
    It's now the second time that an email reaches me in the morning by my 3cx system with the title
    "3CX Phone System - Harddisk is at or near capacity!".
    The mail goes on with
    "3CX installation xxxxxxx.3cx.de is running out of space. (0 bytes Space left out of 500 Mb).
    As a result of this, recordings, logging and voicemail services are disabled until this problem is resolved.
    Login to the machine, free up some space or add more disk space and reboot the server."
    Yesterday it had 94GB of free disk space, this morning it was 8MB only. All processes on the server were freaking out... :-(
    Looking in my folder
    C:\ProgramData\3CX\Instance1\Data\Logs\Backup\20180316
    I found - beside some normal looking files - hundreds of files like those in the red box:
    But the list goes endless with this kind of files, each of them having 16.385 KB.
    The first of the 16.385-files at 00:13 (001351..log) contains data of the day before the catastrophe (15th):
    ------------|Inf(00)| Date: 15.03.2018 00:28:06
    2018/03/15 00:28:06.043|8780|0025|Erro|Can not delete file C:\ProgramData\3CX\Instance1\Data\Logs\3CXPhoneSystem-20180313-011957.blrec, Exception: System.IO.IOException: Der Prozess kann nicht auf die Datei "3CXPhoneSystem-20180313-011957.blrec" zugreifen, da sie von einem anderen Prozess verwendet wird.
    bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    bei System.IO.FileInfo.Delete()
    bei _3cxSystemService.OtherTasks.LogBackups.SafeRemoveFile(FileInfo fi)
    2018/03/15 00:28:06.057|8780|0025|Erro|Can not delete file C:\ProgramData\3CX\Instance1\Data\Logs\3CXPhoneSystem-20180313-011957.blrec, Exception: System.IO.IOException: Der Prozess kann nicht auf die Datei "3CXPhoneSystem-20180313-011957.blrec" zugreifen, da sie von einem anderen Prozess verwendet wird.
    2018/03/15 00:58:06.068|8780|0033|Erro|Can not delete file C:\ProgramData\3CX\Instance1\Data\Logs\3CXPhoneSystem-20180313-011957.blrec, Exception: System.IO.IOException: Der Prozess kann nicht auf die Datei "3CXPhoneSystem-20180313-011957.blrec" zugreifen, da sie von einem anderen Prozess verwendet wird.
    2018/03/15 00:58:07.074|8780|0033|Erro|Can not delete file C:\ProgramData\3CX\Instance1\Data\Logs\3CXPhoneSystem-20180313-011957.blrec, Exception: System.IO.IOException: Der Prozess kann nicht auf die Datei "3CXPhoneSystem-20180313-011957.blrec" zugreifen, da sie von einem anderen Prozess verwendet wird.
    2018/03/15 09:21:04.966|8780|0003|Erro|CHR: Targeting segment is not found for target 8226f469d56c
    2018/03/15 09:31:52.601|8780|0003|Erro|CHR: Targeting segment is not found for target d5353a01473c
    2018/03/15 09:35:14.289|8780|0003|Erro|CHR: Targeting segment is not found for target c61bc4591372
    2018/03/15 09:43:15.477|8780|0003|Erro|CHR: Targeting segment is not found for target e32858259209
    2018/03/15 09:46:28.419|8780|0003|Erro|CHR: Targeting segment is not found for target a3674858d066
    2018/03/15 11:10:40.694|8780|0003|Erro|CHR: Targeting segment is not found for target a15b71145b2d
    2018/03/15 11:16:58.697|8780|0003|Erro|CHR: Targeting segment is not found for target 2e75c61f571b
    2018/03/15 11:50:05.589|8780|0003|Erro|CHR: Targeting segment is not found for target ed5305562902
    2018/03/15 11:50:46.632|8780|0003|Erro|CHR: Targeting segment is not found for target 6453b0732316
    2018/03/15 14:04:50.535|8780|0003|Erro|CHR: Targeting segment is not found for target d170b060d822
    2018/03/15 14:11:35.892|8780|0003|Erro|CHR: Targeting segment is not found for target 4a687c2f6658
    2018/03/15 14:14:51.888|8780|0003|Erro|CHR: Targeting segment is not found for target 684df7193851
    2018/03/15 14:41:15.886|8780|0003|Erro|CHR: Targeting segment is not found for target 881bef4dde16
    Then, day 16 starts:
    ------------|Inf(00)| Date: 16.03.2018 00:13:39
    2018/03/16 00:13:39.238|7312|0001|Inf|Log is created
    2018/03/16 00:13:40.553|7312|0004|Info|Log verbosity is set to Low
    2018/03/16 00:13:42.819|7312|0003|Erro|CHR: Worker thread caught exception: System.Net.Sockets.SocketException (0x80004005): Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
    bei System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
    bei System.Net.Sockets.Socket.Bind(EndPoint localEP)
    bei CallHistoryReceiver.Listener..ctor(IPEndPoint ip_ep)
    bei CallHistoryReceiver.CHReceiver.WorkerMethod()
    2018/03/16 00:13:42.820|7312|0003|Erro|CHR: Worker thread caught exception: System.Net.Sockets.SocketException (0x80004005): Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
    2018/03/16 00:13:42.821|7312|0003|Erro|CHR: Worker thread caught exception:
    and so on... After reaching the end of the file, a new file is created (001400), going on the same way:
    2018/03/16 00:13:51.817|7312|0003|Info|Log is continued
    2018/03/16 00:13:51.817|7312|0003|Erro|CHR: Worker thread caught exception: System.Net.Sockets.SocketException (0x80004005): Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
    2018/03/16 00:13:51.818|7312|0003|Erro|CHR: Worker thread caught exception: System.Net.Sockets.SocketException (0x80004005): Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
    More than 1000 files like this were created...
    The system goes well since 3 weeks but this is now the second time that this happens. I solved the problem by deleting all the log files and rebooting the server. It's a 3cx 15.5.0 on a WIN10 Pro build 16299 running with a AMD X4 940 3GHz processor. The message says something about missing rights of a socket...? But why in the middle of that night and the rest of the days working well?
    Has anyone a helping idea??
    Thank you for your answers!!
    Best wishes from the Rhineland Palatinate (Germany)
    Fritz
  2. StefanW
    Jun 2, 2009
    1,215
    87
    do you have CDR output enabled but nowhere to connect to?
    Settings -> CDR
  3. Fritz Reinhardt
    Jan 30, 2018
    12
    Hello Stefan, thank you for your reply!
    I have a standard version licence - am I right that it does not support any CDR? At least, I don't find any CDR menu in the management console...?!
    But in the parameters list I found some CDR related values like this:
    CDR_LOGGING_PATH C:\ProgramData\3CX\Instance1\Data\Logs\CDRLogs
    CDR_LOGGING_STYLE 1
    CDR_LOGGING_FILESIZE 250
    Is it what you meant?
    By the way, the "CDRLogs" - folder that is mentioned in the "LOGGING PATH Parameter" does not exist in the "Logs" folder. The folder that blew up with hundreds of files was the "Backup"-folder...?!
    What do you think?
  4. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    We will check this one.. I think there were some bug fixes made in this area.. Can you remind me the exact version of 3CX you were using when you reported it?
    Anyway - update this system to the latest version and lets stop the service and delete all the log files and start to monitor.. In the meantime I will check.
  5. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Maybe you have a socket issue on the port you are trying to use.
    Can you check the cdr port and either change it and restart (Make sure you have a listening socket passive or active whatever you configured) or spend some days outputting cdr not to a socket but to a file - see if the problem goes away.
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Could you please check what you have running on port 5484?
  7. Fritz Reinhardt
    Jan 30, 2018
    12
    Thank you for your help and your efforts!!
    This happened just 2 weeks ago and the system was set up just 2 weeks before that, so all happened with the version that was up-to-date on 2018-03-16.
    Okay, now service is stopped, all logs deleted. What do you mean with "start to monitor"? Is there anything more I can do for monitoring than watching log files?
  8. Fritz Reinhardt
    Jan 30, 2018
    12
    CDR in German is KDS. It is turned off.
  9. Fritz Reinhardt
    Jan 30, 2018
    12
    You mean the CallDataRecord=CDR, right? In my German version it's KommunikationsDatenGesetz=KDS. It is completely turned off.
  10. Fritz Reinhardt
    Jan 30, 2018
    12
    Could you please help me with this? What can I do to find out what I have running on port 5484? My router (Fritz!Box7490) has'nt opened this port from the machine to the outside... do you mean that?? Sorry... I'm a beginner... :)
  11. StefanW
    Jun 2, 2009
    1,215
    87
    KDS ist die deutsche Form dafür. Aus den logs kann ich schon klar sehen das es etwas mit der CallHistoryRecords ist (CHR). Dieses und Sockets die nicht angesprochen werden können werden hier bemängelt.
    Hier 3 Dinge zur prüfung
    1. Hotel Modul Aktiviert und kein PMS Server
    2. KDS Ausgabe an auf Socket (Active) aktiviert
    3. AV auf dem Server unterbindet das wir uns auf dem Host Anrufhistorie senden können, wenn du einen Call Report machst, steht da was drin oder ist alles leer?
  12. Fritz Reinhardt
    Jan 30, 2018
    12
    Hello StefanW,
    thank you for your reply! Here is the result of the checks you requested. Can you find something suspicious? What do you mean with AV? Antivirus? There is no antivirus program, even the windows cloud based protection is deactivated.
    Thank you!
    Fritz
    Check 1: Hotel Service
    Check 2: KDS (CDR)
    Check 3: call list and call report
  13. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,327
    73
    V15.5 SP4 was released yesterday, so please update to that version. In the management Console you should then see this:
    What @nb I think meant is after you do the service pack update, stop services, delete all such files, then start services again and monitor to see if it continues to happen.
    Also you have not addressed the question from @MichaelB...
  14. Fritz Reinhardt
    Jan 30, 2018
    12
    Hello NickD,
    thank you for your reply! I've updated to the 10244.4 today, all services stopped, logs deleted, new start. Let's see if it happens again...
    I've asked MichaelB for help, as I don't know how to find out about the port 5484 - how can I see what is happening on this port? Can you give me a hint?
    This is what I found out with netstat -a:
    Proto Lokale Adresse Remoteadresse Status
    TCP 0.0.0.0:5484 ABCD-Server:0 ABHÖREN
    TCP 127.0.0.1:5484 dcba:5606 HERGESTELLT
    TCP 127.0.0.1:5485 ABCD-Server:0 ABHÖREN
    TCP 127.0.0.1:5606 dcba:5484 HERGESTELLT
    TCP [::]:5484 ABCD-Server:0 ABHÖREN
    Does it help you?
    Thank you!
    Fritz
  15. Fritz Reinhardt
    Jan 30, 2018
    12
    Does it help you somehow?
