system disconnects caller
Discussion in '3CX Phone System - General' started by Shawn Gallagher, May 22, 2017.
  1. Shawn Gallagher
    May 22, 2017
    any help would be appreciated. when i transfer to an extension there is silence and it hangs up the call
    cox sip trunk is 192.1681.4
    3cx is 192.168.1.8
    ip phones are 192.168.1.2xx
    3cx has direct access to 1.4 for the sip trunk
    no firewall on internal lan from 3cx to sip trunk
    calls also get disconnected if put on hold from phone after 30 seconds.
    05/22/2017 5:10:06 AM - SLA: 801#0 'idle' -> 'idle'
    05/22/2017 5:10:06 AM - ~CallLeg(C:8.2)
    05/22/2017 5:10:06 AM - InviteADS::destroy:17
    05/22/2017 5:10:06 AM - Call(C:8): Legs count: 2
    05/22/2017 5:10:06 AM - Stop call record for leg L:8.2[Ivr:801]
    05/22/2017 5:10:06 AM - Removing leg L:8.2[Ivr:801]
    05/22/2017 5:10:06 AM - L:8.2[Ivr:801]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    05/22/2017 5:10:06 AM - Leg L:8.2[Ivr:801] is terminated: Cause: BYE from 127.0.0.1:5483
    05/22/2017 5:10:06 AM - Reported(Delete): SE:8.2{OnHook}
    05/22/2017 5:10:06 AM - Issue: [Pres:801; act=Open;0;258]
    05/22/2017 5:10:06 AM - StatusNotification: SE:8.2{OnHook}; Skip=0
    05/22/2017 5:10:06 AM - Device (18xxxxx611) is used in 0 calls: []
    05/22/2017 5:10:06 AM - L:8.2[Ivr:801] got Terminated Recv Req BYE from 127.0.0.1:5483 tid=b19f6d2ee995ac1a Call-ID=9jFqwaLFUjz_Ys1CCbb7tA..: BYE sip:70xxxxx51@127.0.0.1:5060 SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---b19f6d2ee995ac1a;rport=5483 Max-Forwards: 70 Contact: <sip:801@127.0.0.1:5483;rinstance=a506fe3bc0bd9f25> To: "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=cc179d3e From: <sip:801@192.168.1.8>;tag=e0c75d18 Call-ID: 9jFqwaLFUjz_Ys1CCbb7tA.. CSeq: 5 BYE User-Agent: 3CX IVR Reason: SIP;text=User Hung Up Content-Length: 0
    05/22/2017 5:10:06 AM - Terminated from <sip:801@192.168.1.8>;tag=e0c75d18 to "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=cc179d3e; reason: RemoteBye
    05/22/2017 5:10:06 AM - L:8.2[Ivr:801] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=b19f6d2ee995ac1a Call-ID=9jFqwaLFUjz_Ys1CCbb7tA..: SIP/2.0 200 OK Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---b19f6d2ee995ac1a;rport=5483 Contact: <sip:70xxxxx51@127.0.0.1:5060> To: "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=cc179d3e From: <sip:801@192.168.1.8>;tag=e0c75d18 Call-ID: 9jFqwaLFUjz_Ys1CCbb7tA.. CSeq: 5 BYE Content-Length: 0
    05/22/2017 5:10:06 AM - SendMsg from "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=cc179d3e to <sip:801@192.168.1.8>;tag=e0c75d18
    05/22/2017 5:10:06 AM - Sending: OnSendReq Send Req NOTIFY from 0.0.0.0:0 tid=c314731003a56e22 Call-ID=9jFqwaLFUjz_Ys1CCbb7tA..: NOTIFY sip:801@127.0.0.1:5483;rinstance=a506fe3bc0bd9f25 SIP/2.0 Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---c314731003a56e22;rport Max-Forwards: 70 Contact: <sip:70xxxxx51@127.0.0.1:5060> To: <sip:801@192.168.1.8>;tag=e0c75d18 From: "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=cc179d3e Call-ID: 9jFqwaLFUjz_Ys1CCbb7tA.. CSeq: 3 NOTIFY Content-Type: message/sipfrag Subscription-State: terminated;reason=noresource Event: refer;id=3 Content-Length: 18 SIP/2.0 200 OK
    05/22/2017 5:10:06 AM - Reported(Update): SE:8.4{Connected}
    05/22/2017 5:10:06 AM - Issue: [Pres:999; act=Established;0;257]
    05/22/2017 5:10:06 AM - StatusNotification: SE:8.4{Connected}; Skip=0
    05/22/2017 5:10:06 AM - [CM503007]: Call(C:8): VMail:999 has joined, contact <sip:999@127.0.0.1:5483>
    05/22/2017 5:10:06 AM - Reported(Update): SE:8.1{Connected}
    05/22/2017 5:10:06 AM - Issue: [Pres:10000; act=Established;0;256]
    05/22/2017 5:10:06 AM - StatusNotification: SE:8.1{Connected}; Skip=0
    05/22/2017 5:10:06 AM - onLegConnected
    05/22/2017 5:10:06 AM - ~Target=Ext:Ext.999
    05/22/2017 5:10:06 AM - L:8.4[VMail:999] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=f1107520f309620c Call-ID=7UBjdJL8LcB6DtVygr7XGA..: ACK sip:999@127.0.0.1:5483;rinstance=4241ed97d485261f SIP/2.0 Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---f1107520f309620c;rport Max-Forwards: 70 Contact: <sip:70xxxxx51@127.0.0.1:5060> To: <sip:121@3cxhoalv.3cx.us:5060>;tag=e01cc703 From: "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=c3bd0c2b Call-ID: 7UBjdJL8LcB6DtVygr7XGA.. CSeq: 1 ACK Content-Type: application/sdp Content-Length: 212 v=0 o=BroadWorks 45823310644933 45823310644933 IN IP4 192.168.1.4 s=- c=IN IP4 192.168.1.4 t=0 0 m=audio 16654 RTP/AVP 0 101 a=sendrecv a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=ptime:20
    05/22/2017 5:10:06 AM - SendMsg from "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=c3bd0c2b to <sip:121@xxxxx.3cx.us:5060>;tag=e01cc703
    05/22/2017 5:10:06 AM - L:8.1[Line:10000<<70xxxxx51]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    05/22/2017 5:10:06 AM - ~Route=Dev:sip:999@127.0.0.1:5483;rinstance=4241ed97d485261f
    05/22/2017 5:10:06 AM - L:8.4[VMail:999] has joined to L:8.1[Line:10000<<70xxxxx51]
    05/22/2017 5:10:06 AM - Session 406 of leg L:8.4[VMail:999] is connected
    05/22/2017 5:10:06 AM - L:8.4[VMail:999] got Connected.UAC Recv 200/INVITE from 127.0.0.1:5483 tid=1812e55885d7211a Call-ID=7UBjdJL8LcB6DtVygr7XGA..: SIP/2.0 200 OK Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-524287-1---1812e55885d7211a;rport=5060 Contact: <sip:999@127.0.0.1:5483;rinstance=4241ed97d485261f> To: <sip:121@xxxxx.3cx.us:5060>;tag=e01cc703 From: "Shawn G "<sip:70xxxxx51@127.0.0.1:5060;nf=e>;tag=c3bd0c2b Call-ID: 7UBjdJL8LcB6DtVygr7XGA.. CSeq: 1 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Content-Type: application/sdp Supported: replaces User-Agent: 3CX Voice Mail Menu Content-Length: 457 v=0 o=3cxVCE 18446744072339021557 18446744071770954918 IN IP4 192.168.1.8 s=3cxVCE Audio Call c=IN IP4 192.168.1.8 t=0 0 m=audio 12018 RTP/AVP 0 8 3 9 13 97 18 111 110 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:3 GSM/8000 a=rtpmap:9 G722/8000 a=rtpmap:13 CN/8000 a=rtpmap:97 SPEEX/8000 a=rtpmap:18 G729/8000 a=rtpmap:111 iLBC/8000 a=rtpmap:110 iLBC/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 a=sendrecv
    #1 Shawn Gallagher, May 22, 2017
  2. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    173
    60
    Probably not the issue - but - uncheck all options under Extension->Options->Troubleshooting - especially Support Reinvites
  3. leejor
    10,752
    285
    What type, (make/model) phones are you using?
    Is the behaviour different when using different types?
    How do you do the transfer? Blind, attended? Transfer button, hook flash?
    Transferring external calls, or an internal calls as well?
    How do you do a Hold? Is this a set feature?
    Did this just start, or has it always been this way?
