System Extension-Gateway Authentication DID Issue
Discussion in '3CX Phone System - General' started by claxtro, May 30, 2011.
  1. claxtro
    Mar 12, 2011
    22
    First--v10 rocks...period. Now to the issue.
    I have setup a nonsupported gateway (Cisco AS5350) that is connected to our exisiting PBX giving us hybrid 4 digit access to our existing PBX plus full PSTN while our migration to 3CX goes into full force (for 900+ users). All DIDs work great for extensions I have setup in the admin page for Hard IP SIP Phones and the 3CX Softphone. What I am having difficulty with is setting up a DID for a system extension, e.g. a conferencing system extension. When I try to dial through via an external connection through the assigned DID I get this, Please advise. Thank you...Did I mention 3CX rocks! :p
    09:34:15.083 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:6505@172.20.104.10:5060 SIP/2.0
    Via: SIP/2.0/UDP 172.20.104.2:5060;branch=z9hG4bK431C88
    Max-Forwards: 70
    Contact: <sip:6129403221@172.20.104.2:5060>
    To: <sip:6505@172.20.104.10>
    From: <sip:6129403221@172.20.104.2>;tag=97B11A0-11BC
    Call-ID: CFB9BA43-89F711E0-81229C27-9F2832FB@172.20.104.2
    CSeq: 101 INVITE
    Expires: 180
    Min-SE: 1800
    Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
    Call-Info: <sip:172.20.104.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
    Date: Mon, 30 May 2011 13:30:25 GMT
    Supported: 100rel, timer, replaces
    Timestamp: 1306762225
    User-Agent: Cisco-SIPGateway/IOS-12.x
    Allow-Events: telephone-event
    Content-Length: 0
    Remote-Party-ID: <sip:6129403221@172.20.104.2>;party=calling;screen=yes;privacy=off
    Cisco-Guid: 3455055250-2314670560-2150039563-4255255020
    09:34:15.083 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 6505@172.20.104.10:5060 tid=431C88 cseq=INVITE contact=6129403221@172.20.104.2:5060 / 101 from(wire)
    09:34:14.829 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 172.20.104.2:5060;branch=z9hG4bK421EE8
    Max-Forwards: 70
    From: <sip:6129403221@172.20.104.2>;tag=97B10A0-1BE6
    Call-ID: CF92AAE9-89F711E0-81219C27-9F2832FB@172.20.104.2
    CSeq: 101 INVITE
    Expires: 180
    Min-SE: 1800
    Content-Length: 0
    Cisco-Guid: 3457615237-2314670560-2150170635-4255255020
    09:34:14.828 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 6505@172.20.104.10:5060 tid=421EE8 cseq=INVITE contact=6129403221@172.20.104.2:5060 / 101 from(wire)
    09:34:14.564 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 172.20.104.2:5060;branch=z9hG4bK411178
    Max-Forwards: 70
    From: <sip:6129403221@172.20.104.2>;tag=97B0F98-1C2C
    Call-ID: CF6A62A5-89F711E0-81209C27-9F2832FB@172.20.104.2
    CSeq: 101 INVITE
    Expires: 180
    Min-SE: 1800
    Content-Length: 0
    Cisco-Guid: 3460015533-2314670560-2150301707-4255255020
    09:34:14.564 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 6505@172.20.104.10:5060 tid=411178 cseq=INVITE contact=6129403221@172.20.104.2:5060 / 101 from(wire)
    09:34:14.384 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 172.20.104.2:5060;branch=z9hG4bK40101
    Max-Forwards: 70
    From: <sip:6129403221@172.20.104.2>;tag=97B0EE4-26F9
    Call-ID: CF4EE96E-89F711E0-811F9C27-9F2832FB@172.20.104.2
    CSeq: 101 INVITE
    Expires: 180
    Min-SE: 1800
    Date: Mon, 30 May 2011 13:30:24 GMT
    Timestamp: 1306762224
    Content-Length: 0
    Cisco-Guid: 3460775534-2314670560-2150367243-4255255020
    09:34:14.384 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 6505@172.20.104.10:5060 tid=40101 cseq=INVITE contact=6129403221@172.20.104.2:5060 / 101 from(wire)
    09:34:13.969 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 172.20.104.2:5060;branch=z9hG4bK3F1BCF
    Max-Forwards: 70
    From: <sip:6129403221@172.20.104.2>;tag=97B0D44-15E4
    Call-ID: CF0F7041-89F711E0-811E9C27-9F2832FB@172.20.104.2
    CSeq: 101 INVITE
    Expires: 180
    Min-SE: 1800
    Content-Length: 0
    Cisco-Guid: 3466815260-2314670560-2150629387-4255255020
