System/IVR Prompts not working
Discussion in '3CX Phone System - General' started by auzgc, Mar 25, 2010.
  1. auzgc
    Mar 25, 2010
    I have just installed 3CX on Windows 2008 R2 (on a virtual machine under Hyper-V) and followed the instructions to enable Desktop Experience etc but for some reason anytime I make a call to a queue or IVR or voicemail, where there would normally be a prompt of some kind, instead there is just a quick beep.
    This also occurs when making inbound/outbound calls, any time there should be a ring it is just silent. (The destination phone still rings, just the caller receives silence instead of a ring tone)
    I've tried uninstalling, reinstalling 3cx and restarting the virtual machine to no avail.
    The logs aren't showing any errors.
    Any ideas what the cause might be?
    Thanks,
    Martin
  2. bboyd
    Nov 29, 2009
    23
    I am also having the same problem. I had the PBX on another macnine (WINXP) but had to move it to a new one (W2K3 Server) after a screw up on the WINXP computer. Ever since I moved it earlier today I haven't been able to get it to work or find a solution.
    If anyone has a solution would be greatly appreciated.
