System limits document
Discussion in '3CX Phone System - General' started by cygnet, Mar 19, 2012.
  1. cygnet
    Dec 14, 2011
    7
    Hello
    Is there a document detailing the 3CX system limits, e.g. Max Number of lines supported, Max number of caller in a conference, Number of auto attendant trees etc. It would be handy to have this to advise clients on what they can and cannot have.
    Many thanks,
    Azhar ;)
    11,277
    360
    A number of those limits are imposed by how you configure the system and what hardware/network you are running with.
    Number of lines supported, depends on how many digits you use for extension numbering, and how many of those possible numbers are used for other functions.
    I know that there are some very large installations out there, it would surprise me to find that they have hit a limitation, yet.
    In a way, it would be like Ford publishing the maximum speed that each model of it's cars is capable of.
    Perhaps someone from 3CX can comment on the other two limitations that you have brought up.
