System Monitor Offline
zadean
System monitor is showing offline and none of the extensions can register and all show in red. I saw some previous posts on this problem but dont see any resolution?? Running network on XP if anyone can help.
Hi Zadean, try stopping and restarting 3cx and see if it works then.
Look at bat file in this forum
http://www.3cx.com/forums/restarting-the-system-4731.html
Phil
Thanks Phil, that worked.
Went into services and saw that one of the 9 services was not started, started it and its working now
Yes this occasionally happens. I was going to suggest watching for the bat file run an see which service had not started.
I notice this happens ocasionally and I just wonder if its the order the services are started, but the BAT file seems to work every time.
Glad it worked.
Getting Started - Admin
Tammy_53
Get 3CX - Absolutely Free!
3CX
