System Option: Prevent transfer out of voicemail
Discussion in 'Ideas' started by giwm, Apr 28, 2017.
System Option: Prevent transfer out of voicemail 5 5 9votes
5/5, 9 votes
  1. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    With multiple buildings, we're having an issue (with our alarm company first, actually) where they enter the voicemail and the default greeting says to press 'star' to connect to the operator. The caller hits * and gets transferred to one of our office spaces that usually has nothing to do with who they originally called. I can change the extension this goes to (system wide) but I can't turn it off altogether.
    I have no reason to ever let people who get to a voicemail box transfer out. For now I'll edit the default greeting, but I'd rather disable it or have more flexible options on an extension group basis.
    MacPad and StevenH like this.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yup, this is a massive pain ... :(
  3. 3CXDude
    3CXDude New Member
    Oct 1, 2015
    110
    30
    Having the option to define operator/personal attendant per mailbox would be nice.
    JayNZ, StevenH, neville and 1 other person like this.
