System prompt page error
Discussion in '3CX Phone System - General' started by etm_ltd, May 6, 2007.
  1. etm_ltd
    Nov 18, 2006
    69
    Hi all,
    Since I have release to Version: 3.0.1928.0, when access to SYSTEM\PROMPTS,
    i have the following message: (system_recordings.php)
    Notice: Trying to get property of non-object in D:\Program Files\3CX PhoneSystem\Data\Http\system_recordings.php on line 35
    Notice: Trying to get property of non-object in D:\Program Files\3CX PhoneSystem\Data\Http\system_recordings.php on line 42
    Warning: DOMDocument::load() [function.DOMDocument-load]: Input is not proper UTF-8, indicate encoding ! Bytes: 0xE9 0x22 0x20 0x66 in file:///D%3A/Program%20Files/3CX%20PhoneSystem/Data/Ivr/Prompts/Sets/FR_Synth_Carol/SetInfo.xml, line: 30 in D:\Program Files\3CX PhoneSystem\Data\Http\system_recordings.php on line 33
    DOMXPath::__construct() expects parameter 1 to be DOMDocument, boolean given #0 D:\Program Files\3CX PhoneSystem\Data\Http\system_recordings.php(34): DOMXPath->__construct(false) #1 [internal function]: process_xml_file('D:\Program File...', true) #2 D:\Program Files\3CX PhoneSystem\Data\Http\functions\utils.php(401): call_user_func('process_xml_fil...', 'D:\Program File...', true) #3 D:\Program Files\3CX PhoneSystem\Data\Http\functions\utils.php(398): applyForDirTree('D:\Program File...', 'process_xml_fil...', '/SetInfo\.xml$/...', false) #4 D:\Program Files\3CX PhoneSystem\Data\Http\system_recordings.php(48): applyForDirTree('D:\Program File...', 'process_xml_fil...', '/SetInfo\.xml$/...') #5 {main}
    I have reinstall fully twice but no change.
    Does someone else has the same problem?
  2. etm_ltd
    Nov 18, 2006
    69
    [Solved] Prompt error
    Hi again,
    I Have search and find the problem:
    The new installation create a folder named 02g356df.... for the language.
    I have deleted my FR_Synth_Carol folder and the system work perfectly now.
    I have creat a copy and rename it in FR_Synth_Carol from prompt system page and copied my old french files in it. It works.
