System Prompts
Discussion in '3CX Phone System - General' started by techdummy, Dec 12, 2017.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    186
    9
    How can I change the default prompts in the 3CX system v15.5?
    We have been using prompts that were made by us in the previous versions. How can I change the prompts to the ones we have with us?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Create custom prompt set -- copy existing one, modify the prompts you like, then set this prompt set as active. You may need to restart 3CX services or at least media server in order 3CX to load new prompts.
