System requirements on HP machine with HT technology
Discussion in '3CX Phone System - General' started by stog, Jun 29, 2013.
  1. stog
    Jun 29, 2013
    Hello I was wondering it the following system would be suitable to run 3cx
    HP DC7600 with 2.8ghz processor with HT technology as system requirement state you need a dual core processor
    regards
    Steve
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Do not know as you do not state how many calls you anticipate making at any one time. You also did not state the memory or OS that the system will have.
  3. stog
    Jun 29, 2013
    many thanks for reply
    I will be running windows 7 ultimate with at least 3 gig memory(can put in 4 gig if needed) and have 80 gig hard as main and can install second if needed
  4. stog
    Jun 29, 2013
    I would only be looking to have 2 lines
    1 sip line
    1 pstn line via cisco spa3102
    maximum number of call as same time would at max be 3
    regards
    steve
  5. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I ran a few lines through a ThinkPad X31.. I'd expect this machine to handle it okay.
    If not, this model is on eBay for under $30.. I'm betting you could scrape up something with more umph. Considering the price for 7 Ultimate which a 2006 model would not have come up with, the OS is more than the machine, even through non-profit/education channels.
    That X31 was the vanilla XP variety.. handled v10 okay back when I was using it.
    Not to disuade you from using 3CX or troll your thread.. but consider a hosted PBX for a single SIP trunk and a PSTN.. seems that the system may be overkill.. while the hardware is undercooked. :)
  6. stog
    Jun 29, 2013
    Many thanks for your advise it most helpful
    I have a couple of this systems spare so that is way I was asking to see how it would work
    regards
    steve
