System Requirements
Discussion in '3CX Phone System - General' started by jelliott52, Mar 20, 2010.
  1. jelliott52
    Oct 21, 2009
    28
    Hi All,
    I'm bidding on a 70 extension system. How big of a computer system would you suggest. They will be using the 3CX Assistant on 50 extensions and call recording on 8 Customer Service extensions.
    Also, should I use Windows 7 or Windows Server 2008 on this system this size.
    Thanks for the suggestions
    -Jay
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    You will definitely want to go with a big win 2008 system. I would use a quad with at least 4g of ram and a name brand mother board. Cost without OS for around 1200 bucks with prices today....
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    It is all relevant how much the system is going to be used if it is a normal office enviroment the specs mihgt not be too high but if it is a full blow call center you are looking at far higher specs.
