- Joined
- Oct 21, 2011
- Messages
- 73
- Reaction score
- 63
More often than not, the creation of a new extension requires several default 3CX settings to be modified.
Each client usually has a unique set of defaults. Following them while managing dozens of instances requires unnecessary paperwork and effort that could be made more efficient by creating defaults settings.
I'd love to see a "system-wide extension defaults" settings, or, even better, "group-wide extension default settings"
For example:
For example:
- Enable Web Client (Y/N)
- Enable Click to Call (Y/N)
- If yes, default settings for options:
- Voicemail defaults for Date & Time reads, delivery (email, notification, etc.), disable PIN, Play caller ID
- Forwarding rules defaults, specifically, "accept multiple calls"
- Phone provisioning defaults (I know much of this can be defined in the templates)
- BLF Defaults
- Option defaults (example: disallow use outside of LAN is always on by default, but more & more instances are hosted!)
- Record calls
- PBX deliver audio/reinvite & replace support
- etc.
- Etc.
Upvote
10
