System wide 'Speed dial'
Discussion in '3CX Phone System - General' started by Jamie Wright, Nov 14, 2017.
  1. Jamie Wright
    Jun 16, 2017
    I am wanting to know if i can setup a system wide speed dial.
    Instead of using the contacts book i am wanting to give a list of 3 digit speed dial codes to the operators. Eg. code: '201' would call 01234 567891 for example instead of them going through the phone book on there handset. I know i can setup speed dial functions with the blf keys but i need around 400/500 contacts easily accessible.
    The phones i have installed vary slightly, t19p, t27g & t48s.
    10,586
    252
    Jamie Wright likes this.
  3. Jamie Wright
    Jun 16, 2017
    Thanks!
    Would i just dial '*201' once the handset is picked up and press send?
  4. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    you can use a loop trunk to itself and DID table (easy to edit) instead
    create a generic sip trunk without registration to the internal IP address of the PBX
    create 4-digit DID numbers for the trunk like 0000 (limitation of 3CX, or * and 3 digits, like *000)
    edit DID and forward call to external destination
    create an outbound rule with prefix like **, *8 or *66 to use this trunk (and remove 2 or 3 digits, depending on code used)
    to test -- dial a number like *80000 if you have created DID '0000' and use prefix code *8
    #4 sip.bg, Nov 14, 2017
  5. leejor
    10,586
    252
    Keep in mind that using a loop trunk uses two licences per call, one out, and one in.
    And... that example is fine for speed dialling other extensions, (and, unless you are using 5 digit extensions with 3 digit speed dials, I'm not sure what it buys you). If you want to primarily speed dial outside numbers, then you don't really want to send the call out, then back in.
    #5 leejor, Nov 14, 2017
