T.38 fax not quite working
Discussion in '3CX Phone System - General' started by instantexpert, Apr 22, 2011.
  1. instantexpert
    Dec 2, 2008
    92
    After over 15 years of continuous operation, my old US Robotics Courier modem finally died. I went looking for the alternative to the old and, apparently, discontinued 3CX fax send driver. I don't need receive or routing service as MaxEmail does that for me for $9/month.
    I followed these instructions:
    http://www.3cx.com/blog/voip-howto/relayfax-virtual-fax/
    After a bit of pain, I got it working through my Patton gateway but not through my NexVortex/Cogent VOIP line. I abandoned RelayFax because their licensing/costs were more than I wanted to pay. In additional searching, I found this product:
    http://www.t38faxvoip.com/
    They are difficult to setup on 64-bit windows due to driver issues but, once I sorted that all out, I now have a fax solution that integrates with the 3CX PBX and cost $111USD for the t38faxvoip product and $99USD for the Eltima virtual COM port. If anyone else tries this, DO NOT use the alternative Eterlogic port. Only the built in virtual com port (useful for 32 bit only) and the Eltima virtual com ports are supported for use with Microsoft Fax service.
    So, in the end, I have a system that functions for sending faxes through 3CX to my Patton gateway but when I try to send a fax through my VOIP line the call gets dropped. I have included the trace from NexVortex. Can anyone point me in the direction of solving this problem. Is it in the FaxVoip software (I had the same problem with RelayFax) or the 3CX PBX? FWIW, I'm using the latest v9 of 3CX.
    Thank you,
    Leon
    reINVITE with T.38 was sent to your 3CX system and it didn't respond to the reINVITE with T38 codec. and as a result the request times out
    (time in GMT)
    U 2011/04/22 19:47:30.980869 66.23.129.253:5060 -> 173.15.46.68:5060
    INVITE sip:13122558757@173.15.46.68:5060 SIP/2.0..Record-Route: <sip:131225
    58757@66.23.129.253:5060;nat=yes;ftag=gK0bda9f72;lr=on>..Record-Route: <sip
    :206.80.67.68;lr=on;ftag=gK0bda9f72>..Via: SIP/2.0/UDP 66.23.129.253:5060;b
    ranch=z9hG4bKe1ae.9405e66.0..Via: SIP/2.0/UDP 206.80.67.68;branch=z9hG4bKe1
    ae.3b1aed95.0..Via: SIP/2.0/UDP 64.152.60.78:5060;branch=z9hG4bK0bBa1813b5e
    0a32e9cd..From: <sip:13122558758@cogentvoip.com>;tag=gK0bda9f72..To: "DMC,
    Inc." <sip:13122558757@cogentvoip.com>;tag=a95af507..Call-ID: NGQxMmM3MTRjN
    mIzMTNmNTE4MmNmOGQ5ZmE5MTQ1ZTg...CSeq: 18920 INVITE..Max-Forwards: 16..Allo
    w: INVITE,ACK,CANCEL,BYE,REGISTER,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,
    OPTIONS..Accept: application/sdp, application/isup, application/dtmf, appli
    cation/dtmf-relay, multipart/mixed..Contact: <sip:13122558758@64.152.60.78
    :5060>..Supported: timer..Session-Expires: 3600;..m=image 28010 ud
    ptl t38..a=T38FaxVersion:0..a=T38MaxBitRate:14400..a=T38FaxRateManagement:t
    ransferredTCF..a=T38FaxMaxBuffer:262..a=T38FaxMaxDatagram:90..a=T38FaxUdpEC
    :t38UDPRedundancy..a=sendrecv..
    no response from the 3CX PBX and the reINVITE request times out and the call fails to complete. Please make sure your system is setup for T.38 codec for fax
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    does your VoIP provider support T.38?
