T38 VoIP Provider inbound Fax Problem
Discussion in '3CX Phone System - General' started by lploscar, Jan 20, 2012.
  1. lploscar
    Jun 20, 2011
    10
    Hello Everyone,
    I have the licensed version of 3CX, and till yesterday everything was working like a charm :) ... then, the requirement to receive faxes to email came into the picture. I have the default Fax Server ext. 888 configured with a DID, and was testing to see if I can receive faxes to email from outside. No go... Got the etch support (from the SIP trunk provider) on the phone, and after running a trace/capture they emailed me the following:
    "Here's a call trace where you can see that your system swaps from TCP to UDP in the same call which is not allowed by Colt system.
    Please take care about the following 2 RecNO’s:
    1 19/01/2012 13:36:25 984 VoIP SIP 46090 1011 - 100.100.100.100 222.222.222.222 - - Method=INVITE, Method=INVITE
    00000110 Transport 6 TCP
    And then:
    5 19/01/2012 13:36:27 872 VoIP SIP 46090 900 - 222.222.222.222 100.100.100.100 - - Method=INVITE, Method=INVITE
    00010001 Transport 17 UDP
    After this message from your system we can see that Colt system is disconnection the connection with 488 Not Acceptable Here as it can’t go further
    with protocol change in the middle of session.
    6 19/01/2012 13:36:27 875 VoIP SIP 46090 326 - 100.100.100.100 222.222.222.222 - - Status=SIP/2.0 488 Not Acceptable Here, Method=INVITE
    IP & Transport Layers Summary
    00000100 IP Address Type 4 IPv4
    -------- Source Address 222.222.222.222
    -------- Destination Address 100.100.100.100
    -------- Source Port 5060 SIP
    -------- Destination Port 5060 SIP
    Session Initiation Protocol
    -------- Status SIP/2.0 488 Not Acceptable Here
    Please try to change your setting so that your system will stay within TCP from beginning to end of the session."
    Any help would be greatly appreciated...
    (full capture/trace attached)
    Thank you,
    Luc P.
    *edited to add the attachment
  2. lploscar
    Jun 20, 2011
    10
    Problem solved, please close. Provider changed their Invite parameters to allow only TCP... everything works now.
