T42S Template Change
Discussion in 'Ideas' started by Flash99, Aug 17, 2017.
T42S Template Change 5 5 4votes
5/5, 4 votes
  1. Flash99
    Aug 3, 2017
    83
    7
    In your template for T42S the line buttons show user name and under time and date there is an extension number.
    Since there is not much space next to the line buttons and actually a lot of space under time and date it looks much better if you flip between them. Maybe you could update your template so its going to be like this instead ?
  2. npereira@cbnco.com
    Sep 21, 2012
    32
    12
    i do this in my template as the T42S doesnt have enough characters.
    in my yealink_t4x template, I have :
    {IF ua=SIP-T41P,SIP-T41S,SIP-T42G,SIP-T42S}
    #Configure Line Key1
    {IF blf1}
    linekey.1.line = %%Line%%
    linekey.1.value = %%type%%
    linekey.1.pickup_value = %%PickupValue%%
    linekey.1.type = %%DKtype%%
    linekey.1.label = %%label%%
    linekey.1.extension = %%PickupValue%%
    {ELSE}
    linekey.1.type = 15
    linekey.1.label = %%extension_number%%
    {ENDIF}
    #Configure Line Key2
    {IF blf2}
    linekey.2.line = %%Line%%
    linekey.2.value = %%type%%
    linekey.2.pickup_value = %%PickupValue%%
    linekey.2.type = %%DKtype%%
    linekey.2.label = %%label%%
    linekey.2.extension = %%PickupValue%%
    {ELSE}
    linekey.2.line = 1
    linekey.2.type = 15
    linekey.2.label = %%extension_number%%
    {ENDIF}
  3. giwm
    giwm New Member
    Sep 27, 2016
    238
    42
    /me runs out to look at newly provisioned T42S with new template.
    Mmm... yup. In fact, I think even the line buttons on all models should be that way. My T46S line buttons show "1030 | ..." which is kind of pointless.
  4. Flash99
    Aug 3, 2017
    83
    7
    Its very easy to change and we did change it already (as you can see in the image), but it makes it a custom template and ideally we want to be able to be able to work without custom template. This is why I posted this as an idea/request to change
  5. decalabs
    Sep 21, 2016
    15
    You have to set this parameter to 1
    Code:
    features.config_dsskey_length = 1
    Then the buttons are double in size. This is my T46S screen:
    And to stay on topic: Maybe this parameter also exists in the T42S.
    Best regards,
    Dino
