T46 dialing from MyPhone
Discussion in '3CX Phone System - General' started by craigreilly, Jul 15, 2013.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,424
    277
    I know that 3cx has not officially supported the new Yealink T4x phones... but has anyone been able to get MyPhone to dial/control the phone?
    I have the Remote information setup, using 'any for the IP Address for testing as I do not know if the phone server or the workstation actually sends the command. I have tested the string in Safari. And, after it tells me the website is fishing for my password (which it did with the T38 as well) it worked. (IE just says the website wasn't found... security BS I am sure because of the username/password string)
    I am using this string:
    Code:
    http://user:phonepw@phoneIP/servlet?number=%number%
  2. craigreilly
    Feb 1, 2012
    3,424
    277
    They have changed the authentication mechanism to forms based, instead of basic authentication. Therefor, the old dial string (T38) does not work. Yealink say they tried this:
    Code:
    http://10.2.20.20/servlet?number=948&username=admin&pwd=admin
    and it worked for them... I tried in IE and it redirected me to the logon page. I put it into the phone and did a Wireshark trace, and it to was redirected to the logon page.
    My guess it the Yealink Tech Support was already logged into the device when they sent the string...
    Anyone else have a T46 they can test this on?
