T46G - Add group to caller ID
Discussion in '3CX Phone System - General' started by nitramz, Aug 17, 2016.
  1. nitramz
    Aug 3, 2016
    8
    With the new firmware 28.80.0.130 for Yealink T46G the called group is not added to the caller id as before, settings under "contacts" are correct.
    Before 28.80.0.130 it showed callerid:calledgroup
    now it just shows the callerid.
    any advice?
  2. nitramz
    Aug 3, 2016
    8
    it has something to do with this setting
    features.remote_phonebook.enable
    if i disable it works a bit better.
    but as caller name, it shows :CALLEDGROUP
    or NUMBER
    but not NUMBER:CALLEDGROUP
