T48 - purpose of Line keys
Discussion in '3CX Phone System - General' started by Saqqara, Jul 6, 2015.
  1. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    Labelled line keys, but can be used for other functions.
    1. Assign another extension to the phone, configured by modifying the provisioning template or manually via the phone web front end.
    2, Assign other function, same as the blf keys - again modified via phone web frontend.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    391
    53
    I generally leave that in but one customer had us remove them and don't have any negative issues related to it. They can still make calls, make conference calls, answer a second call. I removed it from the template and bumped up the BLF keys accordingly.
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    391
    53
  4. Saqqara
    Mar 12, 2014
    877
    135
    Same here, modify the template to remove these keys - gives you more BLF keys.
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    The keys are there as line keys are the only keys that can be associated to accounts. In some cases, there may be a need to have a single phone assigned to more than one SIP server/provider or multiple extensions.
    As noted, they are programmable so you can tailor to your needs.
