T5XA-58.80.0.40.rom fixes slow dialing:
Discussion in '3CX Phone System - General' started by nobody, Feb 23, 2018.
  1. nobody
    Aug 15, 2017
    77
    https://www.3cx.com/community/threa...ink-t58-fixes-slow-dialing-in-cti-mode.52706/
    I found this link, and indeed on the Yealink page there is a newer Firmware. 0.40. Dialing using this firmware works more like I would expect.
    I wonder why the firmware is still not included in the 3CX updates, since the thread is from december 2017?
    If you want to integrate the update in the 3CX phone system:
    download the update from the yealink page, put the "T58V(T56A)-58.80.0.40.rom" on the 3CX server (windows) under: %programdata%\3CX\Instance1\Data\Http\Interface\provisioning\(YOURURL)\firmware_new\yealink
    rename it to: T5XA-58.80.0.40.rom
    edit the file firmwares.json in the directory above:
    got to the botton of the file. look for the firmware: "Version": "58.80.0.25""
    copy the complete segment beginning to end of the curly braces, and past on the bottom (dont for get to add a "," between the old and the new segment).
    change all occurences of 58.80.0.20 to 58.80.0.40 in the new segment
    save file
    restart management console
    open the management console and update the phones firmware as ususal
    Thank you Brian Cross
    bltech likes this.
