Tagging external lines to Linksys SPA962 with SPA932
Discussion in '3CX Phone System - General' started by shannon, Jun 2, 2009.
  1. shannon
    May 21, 2009
    6
    Hi all have a question relating to the Linksys SPA962 with SPA932, I would like to assign my external lines (PSTN) to the buttons one the SPA932 so the operator would know if the lines are in uses and would also be able to select a particular line to make calls. Is this possible with 3cx and these phones? Thanks again
  2. radcomp
    Aug 21, 2008
    35
    Any Luck on this
  3. leejor
    10,360
    226
    So you want it to operate as a Key system? Sort of defeats the whole point of using 3CX. I'm not sure, myself , if this is do-able. The keys are meant to be datafilled as a "line" , I'd be surprised to find out that you set it up to monitor a trunk.
