Take a call from another extension
Discussion in '3CX Phone System - General' started by AldoLinares, Nov 16, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    How do i take a call from another extension is there a way to take it like with a command or a code?
    Because this really a problem for me i am currently using Linksys SPA921 and X-Lite
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    You can't transfer? Or do you want to park the call? Or answer the call as it rings on another extension?
  3. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    YOu should add in BIN\3CXPhoneSystem.ini
    [Dial Codes]
    pickup = xxx
    xxx= code which dial from other table extension will get the call for you or the requred thing you like to be done to get the call ringing on another desk....
