tapi driver now installs on 32bit Vista
Discussion in 'Windows' started by nb, Jun 20, 2008.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    The next Voip client release will also have Tapi when UAC is enabled - Tested and Fixed already.
