TAPI for Hotdesking
Discussion in 'Ideas' started by crmaddon.com, Dec 6, 2017.
TAPI for Hotdesking 5 5 4votes
5/5, 4 votes
  1. crmaddon.com
    Dec 19, 2008
    It would be nice to get the TAPI working for hotdesking.
    At the moment this is not supported and doesn´t really work (Tested with Yealink and Snom)
    Fun fact: If you run hotdesking with TAPI on Snom or Yealink it will try to use the "line 1" and since the Hotdesking log-off function is overriding this key your phone will be logged off from your extension if you try to call via TAPI.
    jlinds likes this.
  2. Cryjack
    Apr 19, 2018
    6
    NEEDED!
    We paid a lot for 3CX Pro Version to get MultilineTapi for our customer working. Now it's not supported because of Hotdesking enabled.
