TAPI only works with soft phones?
Discussion in '3CX Phone System - General' started by MojoDK, Oct 11, 2010.
  1. MojoDK
    Sep 22, 2010
    26
    I tried out TAPI today and it worked fine ... seams like I need the Assistant installed and the Soft Phone? Weird that I need both.
    Well my question is - if I doen't install the soft phone, will TAPI work with my Snom M9 and other "real" VOIP phones?
    Mojo
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Yes Tapi will work even if you do not install the 3cxphone.
    For tapi to work you'll need to install CRM always.
  3. MojoDK
    Sep 22, 2010
    26
    Hi Michael,
    When you say CRM is that the same as Assistant?
    If I have Assistant + 3cxphone open, my TAPI test in .Net works fine, but if I close 3cxphone, I get an "TAPI outgoing call" event, but the call is never made ... it's not dialing.
    Thanks,
    Mojo
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Well isn't it expected that if you close / turn off your VoIP Phone that you will not receive a call? :mrgreen:
    If you want to receive your Tapi calls on a Hardware phone, simply replace the VoIP Phone with a Hardware Phone.
    Go to your Assistant > File > Preferences > Dialing > Call Via PBX
    Then set up your assistant to have the same Extension number as one of your Hardware phones.
  5. MojoDK
    Sep 22, 2010
    26
    Thanks mate - that was the answer to my question. 8)
    Mojo
