TAPI Programming
Discussion in '3CX Phone System - General' started by lex, Dec 19, 2007.
  1. lex
    lex
    Dec 19, 2007
    Hello. Can you, please, answer my question.
    I'm tyring to develop TAPI aplication. My application is intended for making calls and receiving calls.
    It's OK with making, I get connected to 3Cx provider and it makes a call.
    But I have problem with receiving calls.
    The 3cx client works normally, but my application doesn't get any notifications about incoming calls.
    The question is if 3cx let my application, that is connected to 3cx provider, get incoming calls, or my event handler will never get such calls as my event handler is the last in the list of event handlers and 3cx doesn't transfer incoming calls to that.
    Thanks in advance.
    Lex from Russia.
