Tapi with the server
Discussion in '3CX Phone System - General' started by frenchy, Apr 2, 2008.
  1. frenchy
    Aug 27, 2007
    23
    I would like to use the TAPI driver directly between my application who can use an TAPI pilote functions with the 3CX server.
    I found the TAPI installed with the client voip 3cx, but when I use this TAPI driver, my application send the number to dial to the client voip 3cx. And after this, I can know into my application if the correspondent answered, I can't play a sound message, and I can't hang up.
    So, how can I dial an number, play a sound message if the correspondent give up, hand up the line, directly from my application without using the client Voip 3cx ?
    Regards,
    Frenchy
  2. frenchy
    Aug 27, 2007
    23
    So, is it possible to execute some instructions from an external application to the 3cx server ?
  3. frenchy
    Aug 27, 2007
    23
    Anybody does not use TAPI functions ? :cry:
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Do you want to initiate a call?
    Its possible to launch calls via TAPI - we made that specifically for Outlook so your application should be able to do it in the same way.
    Check this FAQ for an alternate way:
    http://www.3cx.com/support/http-post.html
  5. frenchy
    Aug 27, 2007
    23
    Nick,
    I have checked this FAQ, but I would like to lauch a call, play a message if give up ...
    I develop an application with Windev (http://www.windev.com/) which has TAPI functions.
    Regards,
    Frenchy
  6. frenchy
    Aug 27, 2007
    23
    So there is no solution ?
  7. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    No, there's not. Yet.
