TAPI
Discussion in '3CX Phone System - General' started by donbru01, May 9, 2016.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all , i want create special application where i make call ( via HARD PHONE ) using 3CX TAPI Driver or API ( but i have see on V14 is deprecated )
    I not want install 3CXPhone For Windows , but is my application that manage request to make call toward 3CX Phone System .
    There are a chance ?
    Thanx
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    You may use the Call Control API documented here: http://www.3cx.com/blog/docs/call-control-api/ to create a .NET application which will use the MakeCall() method to trigger a call between the two numbers of your choice.
    TAPI driver will require 3CXPhone for Windows.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi PJ3CX
    Thanx very much
    Bruno
