TAPI
Discussion in 'CRM / Helpdesk / App Integration' started by 3cx newbie, Jan 19, 2018.
  1. 3cx newbie
    Jul 3, 2017
    8
    I'm trying to integrate with a 3cx using TAPI.
    I posted a while ago about this, but had to move onto other priorities, but now trying to get this working.
    Previous post;
    https://www.3cx.com/community/threads/multi-line-tapi-not-working.49693/
    The customer has a standard 3cx system (i.e. not PRO). Version 15.5.0.
    I'm trying to use the phone dialer in windows to place a call, but get an error. I've turned on logging, and in the log file get the following error;
    There is no physical phone connected to this server, but the 3cx client is installed/working.
    Does a physical phone need to be connected on the machine the multi-line tapi driver is installed?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
  3. 3cx newbie
    Jul 3, 2017
    8
    Thanks for the reply @edossantos
    Do you provide an evaluation PRO license, so we can check to see if this works before purchasing the upgrade?
    #3 3cx newbie, Jan 22, 2018
  4. edossantos
    Jun 27, 2007
    1,080
    77
    I'm not sure, you would have to ask that to your sales contact...
